That looks great Jim, one question... do you leave the centers of the "a" and "e" solid, then come back in a second step to inlay them?
Pete
No, not really... I cut the "S" and the "Y" separate, in this case,  and the other letters in two groups.  The inside of the "e" and the "a" I cut as I come to them.  I make a cut through the maple inlay to get to the inside and then  after cutting out the center cedar, back out the same cut to then continue on to cut the outside of the letter.  Kinda' hard to explain and tricky to figure out but now, after doing it many times, I can do it easily.post-2247-0-02391500-1399948688_thumb.jpg You can see how I did this "a"  in another inlay.  The secret is to keep the white, inlay part of the letter to the right side of your blade with the white, maple wood on the bottom and the saw table tilted down on the left.
Give it a try Marge. It isn't as complicated as it seems. Just take your time and get your angle correct for the thickness of wood you choose and the width of the blade and you will whip right thru it and I promise you will enjoy it. :)  :)
I will put it onto my to do list Danny along with Intarsia and metal cutting.
Marg
  • 2 weeks later...
