LarryEA Posted May 13, 2014 Report Posted May 13, 2014 Thank you Grampa for this pattern. I think the wood is Ash. The trim with the cribbage is 1/8 Cherry luaun. The size is 10 1/2 x 10 1/2 inches. Finished with Lacquer. I added it to my albumn. This is one of my favorite cuts. Even with all the mistakes I know about. I do so enjoy when I finish a scroll. Larry lawson56 1 Quote
DWSUDEKUM Posted May 13, 2014 Report Posted May 13, 2014 Now that will make a nice addition to any lakeside retreat. Excellent idea. Thanks for sharing this with us. DW LarryEA 1 Quote
jrpeteo Posted May 14, 2014 Report Posted May 14, 2014 Nice cribbage board! Do you have a hard template or just a pattern for those holes? I've thought about doing one, but I'm afraid of the holes not looking good. Pete LarryEA 1 Quote
LarryEA Posted May 14, 2014 Author Report Posted May 14, 2014 Pete, DW and all who would like round cribbage pattern. Here's what I will do. I have no template. I have a 'very' poor pattern that needs to be clean up. I found a very small picture and kept enlarging it until I got the size I needed. Problem is that when you enlarge some patterns, the circles become like crystals. No real shape. I will made this a priority project to see if I can, using a black marker, make the pattern more useable. and provide it to all. Actually what would be nice is to ... got to explain here There are 24 sets of 5 holes = 120 holes around the circle per player. as you look at the board above, there is about 3+ inches of unused space at the bottom. Need to spread the holes further apart. Enlarging the pattern enlarges everything. Enlarging any more won't work. Though 'you' cannot tell, the holes are toooooooo close together. I screwed up once and that is why there is a cherry boarder on top. It covers the bad holes first drilled so I could try again. I want a good pattern also. I will do what I can and will be back with something. MAYBE I could say more...thats enough lawson56, Rob Roy, jrpeteo and 1 other 4 Quote
Ron Johnson Posted May 14, 2014 Report Posted May 14, 2014 Very beautiful cribbage board Larry. You've done a real terrific job. LarryEA 1 Quote
amazingkevin Posted May 14, 2014 Report Posted May 14, 2014 Talk about precision ,your a neat freak i'll bet,very well done Larry,I'M PROUD OF YOUR WORK HERE LarryEA 1 Quote
wombatie Posted May 14, 2014 Report Posted May 14, 2014 Unusual, never seen one like that before. Great work Larry. Marg LarryEA 1 Quote
lawson56 Posted May 14, 2014 Report Posted May 14, 2014 Awesome job Larry.Drilling all them holes,wheww It came out Awesome. :thumbs: LarryEA 1 Quote
frankorona Posted May 14, 2014 Report Posted May 14, 2014 Wonderful work, looks great and very well done, thanks for sharing. LarryEA 1 Quote
Kepy Posted May 14, 2014 Report Posted May 14, 2014 Great project. Haven't thought about cribbage since my service time. LarryEA 1 Quote
Wilson's Woodworking Posted May 14, 2014 Report Posted May 14, 2014 I love that project and will have to make some of these for myself and my family. I have to admit thou I plan on cheating on the hole pattern. I am going to lay it out in my Cad/cam software and drill the holes with a CNC mill. At the very least I will make a template with the mill. I have one question. Do you have spaces to mark the skunk and double skunk areas? I don’t remember where they are supposed to be. I may have to find a board and count out the number of holes in each area. LarryEA 1 Quote
Fish Posted May 14, 2014 Report Posted May 14, 2014 Boy that really came out nice! Thanks for sharing. LarryEA 1 Quote
Phantom Scroller Posted May 14, 2014 Report Posted May 14, 2014 Larry beautiful work I like that one. LarryEA 1 Quote
LarryEA Posted May 14, 2014 Author Report Posted May 14, 2014 I love that project and will have to make some of these for myself and my family. I have to admit thou I plan on cheating on the hole pattern. I am going to lay it out in my Cad/cam software and drill the holes with a CNC mill. At the very least I will make a template with the mill. I have one question. Do you have spaces to mark the skunk and double skunk areas? I don’t remember where they are supposed to be. I may have to find a board and count out the number of holes in each area. Danny, what is the skunk and double skunk areas? All holes in this pattern are the start, count and end holes You may be a solution to a problem. I was prepaired to post my pattern but the pattern has problems I cannot fix. Here are the details: Most Standard cribbage pegs require an 1/8 hole Ergo...All holes should be drilled with 1/8 bit. All holes should be 1/8 inch apart all sides, front/back right/left. All 5 hole groups should be 1/4 inch apart. My pattern does not meet these standards But there is room for expansion at the bottom of the pattern where there is 5 inches of free space.. I do not have ability to expand the pattern to the correct dimension. This was a copy from 'How to Play' book that I enlarged. I will not post the pattern until I hear from you that you can or cannot enhance it. Quote
Wilson's Woodworking Posted May 14, 2014 Report Posted May 14, 2014 (edited) Try scaling this to the proper size and see if it works better for you. I left a double space after each 8 groups of 5 for the skunk and double skunk markings. I removed pattern to save people from using a bad pattern Edited May 15, 2014 by Wilson's Woodworking LarryEA 1 Quote
LarryEA Posted May 14, 2014 Author Report Posted May 14, 2014 I saved and printed. I get 1/4 page print and will have take it to print center to have it enlarged. Let you know later Wilson's Woodworking 1 Quote
ubgoofy2003 Posted May 14, 2014 Report Posted May 14, 2014 Looks great & is a real nice combination. You came up with a real nice idea & it looks great. Thanks LarryEA 1 Quote
Rover2 Posted May 15, 2014 Report Posted May 15, 2014 Very nice Larry. Thanks for sharing. You so some wonderful work. LarryEA 1 Quote
LarryEA Posted May 15, 2014 Author Report Posted May 15, 2014 Cribage board hole pattern..jpgTry scaling this to the proper size and see if it works better for you. I left a double space after each 8 groups of 5 for the skunk and double skunk markings. Danny, check 6th group of 5... missing a row. Only has a count of four Quote
Lucky2 Posted May 15, 2014 Report Posted May 15, 2014 It's a gorgeous crib board, who wouldn't want one just like it? I do have an issue with it and the new pattern that Danny has supplied, it's a small issue, but, for me it's an issue. The holes are in reverse of what they should be, you don't play crib by counting down backwards or counter clockwise, you play your pins in a clockwise motion. It's an easy fix, all you have to do is reverse the pattern Paul and Danny has provided. Len LarryEA 1 Quote
Wilson's Woodworking Posted May 15, 2014 Report Posted May 15, 2014 It's a gorgeous crib board, who wouldn't want one just like it? I do have an issue with it and the new pattern that Danny has supplied, it's a small issue, but, for me it's an issue. The holes are in reverse of what they should be, you don't play crib by counting down backwards or counter clockwise, you play your pins in a clockwise motion. It's an easy fix, all you have to do is reverse the pattern Paul and Danny has provided. Len Your right I missed that one. I will fix it and repost the pattern Lucky2 1 Quote
Wilson's Woodworking Posted May 15, 2014 Report Posted May 15, 2014 Take a look at this one and see if you see any problems. I think it is ready to scale and use. If this one is correct maybe some of our wonderful pattern makers can fill the center with different options of boards to cut. LarryEA, Lucky2 and jrpeteo 3 Quote
smitty0312 Posted May 15, 2014 Report Posted May 15, 2014 That is one awesome cribbage board, work was executed very well, and one last thing....... awesome talent! LarryEA 1 Quote
LarryEA Posted May 15, 2014 Author Report Posted May 15, 2014 It's a gorgeous crib board, who wouldn't want one just like it? I do have an issue with it and the new pattern that Danny has supplied, it's a small issue, but, for me it's an issue. The holes are in reverse of what they should be, you don't play crib by counting down backwards or counter clockwise, you play your pins in a clockwise motion. It's an easy fix, all you have to do is reverse the pattern Paul and Danny has provided. Len Len, there are two solutions, maybe three at least. 1) print mirror image 2) use scissors and tape. cut and move the start and finish holes. 3) Whiteout and a black marker. Maybe it will be modified... I don't want to use the word 'fixed' cause it ain't broke. Anyway. I appreciate very much the compliment from you. Makes me feel good. Quote
LarryEA Posted May 15, 2014 Author Report Posted May 15, 2014 That is one awesome cribbage board, work was executed very well, and one last thing....... awesome talent! Thank you!! I get an error when I click 'Like This' I would 'Like' your comment but I must have liked too much. Quote
