I found a project on here that I think will be a good start for me. Its a buck deer found in the library, I have some 3mm craft ply to cut it out on. The nose looks a little tricky, any tips on that. What are some good ways to do the black backing on a project like this?
I'm simple, just use any type black paint on a backer board.
You only need to paint the part of the backer that will be exposed.
For most items like this deer head, you do not need to be a perfectionist for
the black for the backer. The cuts are small so again just a little black will do it.
IMHO
Chet, What Dan said is correct. I call them bridges or anchors.
Before you make a cut be sure there is adequate support.
I have cut this pattern a few times and I think it is a great learning
experience. I grade it moderate.
Your blade choice is always important. Experiment if you have a variety of blades.
Blade choice may change depending on wood type and thickness.
