rjR Posted January 26, 2016 Report Posted January 26, 2016 Help will be appreciated; My type 2 DW 788 has started to have issues; binding in the bearings --sometime knocks, sometmes does not! Does anyone know where a bearing kit with all of the bearings is available; so I can have them on hand to replace all at one time. I know I have several going out! I only want to take it apart once; not several times. I also want to be able to do all of the bearings at one go! It makes no sense to me to have it down and then search for each bearing, I think there should be an "overhaul" kits available like there are for engines! Quote
Scrappile Posted January 26, 2016 Report Posted January 26, 2016 have you looked here? I've had good luck buying parts from them. http://www.ereplacementparts.com/dewalt-dw788-type-scroll-saw-parts-c-1009_2631_207564.html Quote
NC Scroller Posted January 26, 2016 Report Posted January 26, 2016 Sorry rjR but I do not think they sell a kit. You kinda have to dissemble and see which are bad. In may cases a good coat of grease will cure many of the issues. Quote
DonR Posted January 26, 2016 Report Posted January 26, 2016 I purchased my bearings from VXB Bearings. http://www.vxb.com/The following lists the bearings required for a 40-694 which I believe is the same as the DW788. Each kit is 1 bearing so you need to know how many of each that you need. Hope this helps you. A good quality grease is your best friend. Kit8616 HK0609 Needle Bearing 6x10x9 TLA609Z Miniature Needle Bearings 1 $4.37 Kit7189 HK1412 Needle Bearing 14x20x12 TLA1412Z Needle Bearings 1 $5.77 Kit7492 HK0810 Needle Bearing 8x12x10 TLA810Z Miniature Needle Bearings 1 $5.77 Don R New Guy 1 Quote
JustLarry Posted January 26, 2016 Report Posted January 26, 2016 (edited) Post #8 is link to DW788 repair video. Shows you how to do the bearings and much, much more. http://www.scrollsawvillage.com/topic/16873-dw788-service/?hl=788 Larry Post I made in 2013 shows the same bearing numbers that Don R shows. Just looked up price at vxb and they are also the same. HK0609 12 ea HK7492 2 ea HK7189 2 ea. I have not changed the bearings on my 40-690 which are the same nor have I ordered the bearings. I provide this information as something I have read on the internet and we all know what you read on the internet is true? Edited January 26, 2016 by JustLarry Quote
bandaideman Posted January 26, 2016 Report Posted January 26, 2016 The link that Larry gave I have watched and it is very through and worth the time. I have not replaced anything or greased yet but know this will need doing this year. I think I will have a engineer who is a friend of mine standing by to help. I know 4 of them. They are very particular on doing everything which is a good thing. JustLarry 1 Quote
Lucky2 Posted January 27, 2016 Report Posted January 27, 2016 Dan, that is the last thing you would want to do, engineers have a tendency of costing you more money and time. Len Quote
CharleyL Posted January 27, 2016 Report Posted January 27, 2016 If you take those quantities and numbers with you to a bearing store and tell them that you want better quality tighter tolerance bearings for each of them it will cost you a few bucks more, but your saw will perform better than it did when new. I did this the last time that I rebuilt my DeWalt 788 type 1 and it made a huge difference in saw performance at a cost of only about $18 more total for all of the bearings. Any play at all in the back and forth movements produces noise and vibration. Tighter tolerance bearings significantly reduces these noises and vibrations. Look for a bearing or power transmission parts supplier in a larger city near you in the yellow pages. You will get replacement parts for less money or better parts for just slightly more if you buy from them instead of the saw parts supplier. Even Fastenal usually has better prices on bearings than the saw parts suppliers, but you may not be able to get the tighter tolerance bearings from them. Charley Quote
heppnerguy Posted January 27, 2016 Report Posted January 27, 2016 Help will be appreciated; My type 2 DW 788 has started to have issues; binding in the bearings --sometime knocks, sometmes does not! Does anyone know where a bearing kit with all of the bearings is available; so I can have them on hand to replace all at one time. I know I have several going out! I only want to take it apart once; not several times. I also want to be able to do all of the bearings at one go! It makes no sense to me to have it down and then search for each bearing, I think there should be an "overhaul" kits available like there are for engines! Ralph, Check out this video.. this same guy has an even better repair video in you tube. should be easy enough to find too.. Dick heppnerguy Quote
rjR Posted January 28, 2016 Author Report Posted January 28, 2016 Thanks Everyone! Appreciate the help! Ordered bearings. Will tear down saw when they arrive! Quote
amazingkevin Posted January 30, 2016 Report Posted January 30, 2016 Good thing is you 'll be a dw788 repairman in demand soon! Quote
